2000 Chevy Impala Knock Sensor Location
BENJAMINONEIDA
i have a 2000 chevy impala 3.8 v-6, with 100000 miles on it. it has a bad knock sensor in it. the problem is, i cannot find the sensor to change it. i just need to know where the sensor is located. PLEASE HELP!!!
May 1, 2007 at 7:35 AM
SCOTTALLEN333
the sensor is probably located on the front or back side of the motor below the heads.
May 10, 2007 at 3:39 PM
  • 75,988 POSTS
[quote:2ca55430fb="benjaminoneida"]i have a 2000 chevy impala 3.8 v-6, with 100000 miles on it. it has a bad knock sensor in it. the problem is, i cannot find the sensor to change it. i just need to know where the sensor is located. PLEASE HELP!!![/quote:2ca55430fb]
Engine 3.8 VIN K has 2 (two) of them
Bk1 at lower left side of engine near the starter
Bk2 @ lower right side of engine right besides the power steering pressure sensor.
Good Luck
May 10, 2007 at 7:19 PM
Suggested Repair
On the 3.8 VIN K, locate the two knock sensors: bank 1 at the lower left side of the engine near the starter, and bank 2 at the lower right side beside the power steering pressure sensor.
Conversation Summary
The owner of a 2000 Chevy Impala 3.8 with about 100,000 miles cannot find a bad knock sensor and asks for its location. An expert says the VIN K engine has two sensors: one at the lower left near the starter and one at the lower right beside the power steering pressure sensor.
