1996 Chevy Lumina P0401 EGR Flow
1940 CHEVROLET
R&S
I HAVE A 1996 CHEVY LUMINA 3.1 V6. 112,000 MILES ENGINE LIGHT HAS COME ON. MY OB11 CODE READER SAID CODE P401, INSUFFICIANT AIR FLOW.
I HAVE REPLACED THE ELECTRONOC EGR VALVE WITH A NEW ONE BUT ENGINE LIGHT STILL COMES ON. WHAT ELSE COULD IT BE?
Jan 9, 2007 at 5:34 AM
CARUNDELL
  • 602 POSTS
[quote:ffd533b83f="R&S"]I HAVE A 1996 CHEVY LUMINA 3.1 V6. 112,000 MILES ENGINE LIGHT HAS COME ON. MY OB11 CODE READER SAID CODE P401, INSUFFICIANT AIR FLOW.
I HAVE REPLACED THE ELECTRONOC EGR VALVE WITH A NEW ONE BUT ENGINE LIGHT STILL COMES ON. WHAT ELSE COULD IT BE?[/quote:ffd533b83f]
Hey R&S
Sounds like the passage in the intake is clogged w/ carbon build up. Not an easy one to clean but, your going to need carb cleaner, some small wire brushes and maybe even a coat hanger or two! Well maybe not the coat hangers ........ Let us know!
Chris
Jan 9, 2007 at 5:40 AM
R&S
[quote:51442c1ce8="R&S"]I HAVE A 1996 CHEVY LUMINA 3.1 V6. 112,000 MILES ENGINE LIGHT HAS COME ON. MY OB11 CODE READER SAID CODE P401, INSUFFICIANT AIR FLOW.
I HAVE REPLACED THE ELECTRONOC EGR VALVE WITH A NEW ONE BUT ENGINE LIGHT STILL COMES ON. WHAT ELSE COULD IT BE?[/quote:51442c1ce8]
I noticed that wiith the egr valve plugged in but not bolted in place, the valve did not move when i acclelerate with the old valve, or the new egr valve.
shoudnT the piston move up and down when you rev the engine. Also have checked the fuse for egr it is fine. what elso could it be not paking the valve/piston on egr not move
Jan 10, 2007 at 10:50 AM
Suggested Repair
Clean carbon buildup from the EGR passages in the intake using carburetor cleaner and small wire brushes. The expert did not address why the EGR pintle does not move when the valve is unbolted.
Conversation Summary
A 1996 Chevy Lumina 3.1 owner has a check-engine light with code P0401, insufficient EGR flow, after replacing the electronic EGR valve. Expert Chris said the intake passage is likely clogged with carbon and should be cleaned with carburetor cleaner and small wire brushes. The owner later said the EGR pintle does not move when the valve is plugged in but not bolted and the engine is revved, and that the EGR fuse is good; that follow-up was not answered.
