1997 Chevy Lumina P0401 EGR Flow
CHEVROLET
DABOSS
  • 5 POSTS
I got a 1997 Chevy Lumina, 120,400 miles on it, she still runs, but my question is this, there's a hose-like pipe from the bottom of the EGR Valve to the Intake Manifold, can that be tooken off? might sound dumb, nut I gotta know. I wanna clean it out and see if that'll fix the problem because I got the P0401 engine code, Insufficient EGR flow. someody let me know.
Jul 4, 2006 at 4:05 PM
MIKEYBDMAN
  • 623 POSTS
If no modifications to the exhaust system have been made, then inspect the exhaust system for leaks. If no leaks, remove the EGR valve and insp the pintle, valve passages and adapter for excessive deposits or any kind of restriction. Check EGR gasket for leaks or pipe leaks.
If no problems, remove the EGR inlet and outlet pipes from the manifold and insp ports and pipes for deposits, or obstructions.
If that doesnt help, you are going to have to start chasing wires.
Jul 8, 2006 at 7:47 AM
POPALONI
CHEVY
LUMINA
1997
I WAS WONDERING WHAT YOU HAD TO DO TO YOUR CAR? HAVING SAME PROBLEM AND DUE FOR EMISSIONS AT END OF MONTH.
THANKS, PAUL
Oct 19, 2006 at 5:45 AM
Suggested Repair
Inspect the exhaust for leaks, then remove the EGR valve and check the pintle, passages, adapter, and gasket for deposits or leaks. If clear, remove the EGR inlet and outlet pipes and inspect the ports and pipes for restrictions. If those checks do not resolve P0401, test the related wiring.
Conversation Summary
The owner of a 1997 Chevy Lumina with code P0401 asked whether the pipe between the EGR valve and intake manifold could be removed and cleaned to restore EGR flow. The expert advised checking for exhaust leaks, inspecting the EGR valve, gasket, passages, and pipes for deposits or restrictions, and then checking wiring if no restriction is found. A later user reported the same problem but no repair outcome was confirmed.
