1983 Chevy Silverado Choke Light Stays On Fix
CHEVROLET
FYRPUPPY
My choke light stays on all the time and the truck diesels when you shut it off. 1983 silverado 4x4 just barely 100 miles on a jasper replacment engine. i have replaced the choke thermostat and this did not change anything. I am being given the runaround by the guys that just repalced the motor so I am trying to handle it myself.
Jan 18, 2007 at 4:10 PM
  • 75,988 POSTS
[quote:cd6f4002fb="fyrpuppy"]My choke light stays on all the time and the truck diesels when you shut it off. 1983 silverado 4x4 just barely 100 miles on a jasper replacment engine. i have replaced the choke thermostat and this did not change anything. I am being given the runaround by the guys that just repalced the motor so I am trying to handle it myself.[/quote:cd6f4002fb]
You need to adjust your fast idle cam-the reason you're dieseling is because the throttle plate is not fully closed creating your Run-on. Some thing is holding the plate open investigate thoroughly. and also recheck the ignition timing.
Jan 18, 2007 at 9:00 PM
FYRPUPPY
It didn't start doing this till the choke light came on and now it will not go off. I checked the voltage going to the choke thermostat( I was told it probably didn't have any power. It has DC voltage with the switch on and with the truck running.
Jan 19, 2007 at 2:23 AM
Suggested Repair
Adjust the fast idle cam so the throttle plate closes fully, inspect for anything holding the plate open, and recheck ignition timing. The choke light remaining on and voltage at the choke thermostat should also be considered while diagnosing the run-on.
Conversation Summary
The owner of a 1983 Chevrolet Silverado 4x4 with a recently installed Jasper replacement engine says the choke light stays on and the truck diesels after shutdown. Replacing the choke thermostat did not help, and voltage is present at the choke thermostat with the key on and the engine running. The expert attributes the run-on to the throttle plate not closing fully and advises adjusting the fast idle cam, finding what holds the plate open, and rechecking ignition timing.
