Chevy 250 L6 Idle Problem
1925 CHEVROLET
BLACKJACK61304
I have A chevy 250 engine out of a mid 70's Nova. It is equiped with a Rochester 1bbl carb. The Engine wants to die when it is shifted into gear. It is an automatic. I believe that it may be a carb problem, but I dont know what the timing should be set at. any recomendations or comments would be greatly apreciated
thanks
Oct 31, 2006 at 4:11 PM
HMAC300
  • 48,601 POSTS
with the engine off take the air cleaner off and see if the carburetor will shake or seem loose. these had a habit of two screws that hold the float bowl to the base loosen up and cause vacuum leaks /idle problems. You will have to remove the carb to tighten the screws. if you do put loctite on the screws (242 or "BLUE) . the timing should be 4 degrees or so BTDC.
Dec 15, 2009 at 9:56 AM
