1970 Chevy Nova 250 engine
SPONDS
  • 1970 CHEVROLET NOVA
Not getting any fire to the spark plugs, any suggestions?
Tuesday, November 13th, 2007 AT 1:23 PM
Pull the coil wire at the distributor-ground it to the engine and crank engine over-do you have spark. No spark check for power at the coils power input terminal power there.
Could be the ignition contact point/s or the ICM if its an HEI
Tuesday, November 13th, 2007 AT 1:47 PM
ED ARMES
  • 129 POSTS
70 Nova has conventional ignition system with points and condensor. Major reasons for no fire are: coroded connections in distributor, bad points or condensor, poor adjustment on points (.017 to.019 ), bushings bad in distributor that do not open points properley ( common ).
Friday, February 29th, 2008 AT 9:12 PM
Check the coil's primary and secondary windings. Then adjust the contact points as stated then use a dwell meter and adjust the dwell angle.
Friday, February 29th, 2008 AT 9:38 PM
