1971 Chevrolet Nova Starter Grinding
MADRICK
I have a 71 Nova with a 350 and a saginaw 4 speed. I have had the same problem with about 5 different starters now. None brand new. When I put the starter on it will work fine at first, maybe sound like it needs a shim or two but still turns the engin over pretty well. After I have started the car a few times the starter will start to grind real hard and wont turn the engin over. So I will put some shims in it untill it sounds and works like it should. Then after I turn it over a few different times, it does it again. Then I will go through the entire process again, but I still have had to luck.
P.S. I had a turbo 350 transmission with 2 different flyweels on it before the 4 speed and had the same problem. And one of these 2 flywheels were brand new. Still had the same problem.
Apr 29, 2007 at 5:47 PM
MADRICK
My last subject was starter haning and I ment to type "Starter Hanging Up."
Apr 29, 2007 at 5:49 PM
  • 75,988 POSTS
[quote:aadf9e1f5a="Madrick"]My last subject was starter haning and I ment to type "Starter Hanging Up."[/quote:aadf9e1f5a]
Remove the inspection cover-now manually engage the drive pinion to the flexplate-where the V on the flywheel meets the gear teeth on pinion should be .060- Got this funny feeling you're still far away from it. I know how it is I tried that with a 350/350 76 Blazer keep shimming till you get it right- That's how chevy is-shim-shim-shim till its right.
Good Luck
Apr 29, 2007 at 7:43 PM
Suggested Repair
Remove the inspection cover and manually engage the starter drive pinion with the flywheel or flexplate. Set clearance where the flywheel V meets the pinion teeth to about 0.060 inch, adding or adjusting shims until engagement is correct and the starter no longer hangs or grinds.
Conversation Summary
The owner of a 1971 Chevrolet Nova with a 350 and Saginaw four-speed reports that several used starters work briefly, then grind and fail to turn the engine. Shimming helps only temporarily, and the same problem occurred with a previous Turbo 350 and different flywheels. The expert recommends checking pinion-to-flywheel engagement through the inspection cover and shimming until the clearance is about 0.060 inch.
