2005 Other Chevrolet Models Oil in Blow Pipe
2005 CHEVROLET
130,000 MILES • 4 CYL • 2WD • MANUAL
NADY7321
I have chevrolet 800cc (LS Exclusive-Matiz). There is significant oil deposit in air cleaner. This oil is drpping from the blow pipe. Have also replaced PCV but no use. When i start the vehicle at morning it blows water from the silencer which is always good sign of healthy engine.
Apr 23, 2010 at 11:28 PM
HMAC300
  • 48,601 POSTS
this is probably designed to draw fumes into the air cleaner. the baffling in the valve cover may not be sufficient to cause the is or check the oil cap to see if there is a breather element that needs cleaning may be causing this......
May 13, 2010 at 11:28 AM
