1999 Other Chevrolet Models Car is missin
1999 CHEVROLET
93,000 MILES • 4 CYL • FWD • AUTOMATIC
KSTANEART
my car is missin, we changed the air filter, spark plugs, and we added a fuel and injector cleaner. Car is still missin, what else can i check or do before a machanic is required?
Mar 11, 2009 at 12:06 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Mar 11, 2009 at 12:10 PM
