1989 Other Chevrolet Models carburetor excelleration from st
1989 CHEVROLET
18,900 MILES • V8 • 2WD • AUTOMATIC
OKLAKID60
89chev1500 carburetor acts like choke is closed all the time,no power engine stalls,hesitates on take off. replaced plugs,rotor cap,distributor cap,air filter,fuel filter,pvc plug,control module for distibutor,still hard to start,engine run fast and slow at idle, after taking off very slow hesitating the more gas you try to give it,then at about 35 or 40mph when you kick in 2nd barrel it will kick in and excelerate very good. It will die when you stop,but restarts good. what is wrong??
Mar 18, 2010 at 6:46 PM
Check the fuel pressure if its within specs if okay clean out the EGR valve and see what happens
Mar 19, 2010 at 12:16 AM
OKLAKID60
[quote:3623694c54="oklakid60"]Engine Performance problem
1989 Other Chevrolet Models V8 Two Wheel Drive Automatic 189,00 miles
89chev1500 carburetor acts like choke is closed all the time,no power engine stalls,hesitates on take off. replaced plugs,rotor cap,distributor cap,air filter,fuel filter,pvc plug,control module for distibutor,still hard to start,engine run fast and slow at idle, after taking off very slow hesitating the more gas you try to give it,then at about 35 or 40mph when you kick in 2nd barrel it will kick in and excelerate very good. It will die when you stop,but restarts good. what is wrong??[/quote:3623694c54]
Mar 19, 2010 at 6:44 PM
Check the Carb's accelerator pump if its squirting fuel when you pull the throttle back
Mar 19, 2010 at 7:22 PM
