Hi, carbed engine, mechanical fuel pump? How long since a tune-up? If carbed engine, if the choke closes, it'll kill a hot engine. Maybe you just need a carb kit? The instructions are in the kit.
Where applicable, sometimes, with extended crank, I remove the airhorn from carb without removing carb, see if any gas in float bowl.
SPONSORED LINKS
Tuesday, February 9th, 2010 AT 2:19 PM
