Sounds like the float is not adjusted right, adjust it or, replace that rebuild with another one. Rebuild are like a box of chocolates. You never know what your gonna get! The other chance you might have, can you get to the mixture screws on the front? If so, turn them all the way in, then back out 3 turns on both, see if it will run, adjust the mix while it's running with a tach, play with them till you get the highest rpm at idle. Be careful when you turn them screws in, Gently now, the seats and needles are easily flattened!
Friday, December 14th, 2007 AT 6:07 PM
