1977 Chevrolet Nova 350 Swap Fit
ARREDJA
1.Chevy Nova 1977
2.26,000 2nd life
3.Automatic
4.2 Wheel drive
5.Inline 6 has valve slaps
6.No fluid leaks
Q:Will a 350 5.7 Liter small block V8 line up with the transmission I already have or will I have to buy a new one?
Jun 14, 2007 at 7:51 AM
JIM450HP
We just put a 350 in a 74 that had a six and everything lined up great.
Jun 19, 2007 at 11:23 AM
ED ARMES
  • 129 POSTS
The one problem you may have would be that they changed fly wheel and starter setups over the years. As long as you use a current model engine or check the numbers with GM, you should be OK.
Feb 29, 2008 at 1:40 PM
NOTOUCHEE
you need to change the motor mounting bracet on the frame
May 3, 2009 at 3:59 PM
Suggested Repair
A 350 may line up with the existing automatic if the flywheel and starter match the transmission. Use a compatible engine or verify the numbers with GM, and replace the frame motor-mount brackets.
Conversation Summary
The owner of a 1977 Chevrolet Nova with an inline-six and automatic asked whether a 350 small-block would bolt to the existing transmission. One owner said a similar six-to-350 swap lined up. The expert warned that flywheel and starter setups changed over the years and advised using a matching current engine or checking numbers with GM. Another reply said the frame motor-mount brackets must be changed.
