1998 Chevy Monte Carlo Fuel Pump
BURGHARDT2376
Where is the fuel pump located on a 1998 Chevy Monte Carlo and how would you go about changing this? :D It has about 120,000 miles and I believe a 3L engine
Mar 2, 2007 at 2:26 PM
  • 75,988 POSTS
Y R U trying to find the pump? The pump is in the gas tank.
Mar 4, 2007 at 5:25 PM
BURGHARDT2376
It is believed that the pump has gone bad on my car and needs to be replaced. Is it hard to change?
[quote:4856675bcd="rasmataz"]Y R U trying to find the pump? The pump is in the gas tank.[/quote:4856675bcd]
Mar 7, 2007 at 1:42 PM
  • 75,988 POSTS
[quote:497fc95aa4="Burghardt2376"]It is believed that the pump has gone bad on my car and needs to be replaced. Is it hard to change?
Siphon it out and than lower the straps that holds it up then go from there.
[quote:497fc95aa4="rasmataz"]Y R U trying to find the pump? The pump is in the gas tank.[/quote:497fc95aa4][/quote:497fc95aa4]
Mar 7, 2007 at 7:26 PM
Suggested Repair
The fuel pump is inside the gas tank. Siphon the fuel out, then lower the tank support straps to access the pump.
Conversation Summary
The owner of a 1998 Chevrolet Monte Carlo with about 120,000 miles asked where the fuel pump is and how to replace it, believing it had failed. The expert said the pump is in the gas tank and advised siphoning the fuel, then lowering the straps that hold the tank so the pump can be accessed.
