1999 Chevy Monte Carlo Fuel Pump Hum
K8PEREZZ
I have a 1999 Chevy Monte Carlo 3.1. I just replaced the fuel pump because it was making a humming sound and I was having problems starting the car. After replacing the fuel pump and fuel filter the humming noise is still there. What is making the fuel pump make the humming noise? Is it the fuel pump relay? Please if you have any ideas let me know. Thanks
Jun 3, 2007 at 5:52 PM
RUDPRO
  • 224 POSTS
No, the relay wouldn't make it hum. Are you still having starting problems? Was the new pump from a Chevy dealer or an aftermarket pump. Some pumps are just loud. I found complaints from other people with loud pumps but they were usually on Chevy trucks. I would check your fuel pressure and make sure it's where it should be. You may just be stuck with a noisy pump. Are you sure it's the pump though. Turn the key to run (engine off), listen, the pump should come on for 2 seconds and shut off. Is this the same sound you hear? Listen at the tank with the cap off while someone else turns the key to run. Just saying, make sure it's the pump. You may just have a noisy pump. Save your receipt if it's under warranty. The new pump could possibly be defective.
Jun 4, 2007 at 3:02 PM
Suggested Repair
Confirm the hum is the fuel pump by listening at the tank with the key in run and the engine off. Check fuel pressure. The relay does not cause the noise. A new pump may be noisy or defective, so keep the receipt for warranty.
Conversation Summary
The owner of a 1999 Chevy Monte Carlo 3.1 replaced the fuel pump and filter because of humming and hard starting, but the hum remains and asks if the relay is the cause. The expert says the relay would not hum, advises confirming the sound during the two-second prime, checking fuel pressure, and notes some pumps are loud or the new unit may be defective.
