1998 Chevrolet Monte Carlo A/C Leak
I have a 1998 Monte Carlo z34 with a 3.8L 3800 engine. My air conditioner compressor has leaked somthing oily. I checked under the hood after doing some research, and i found that the compressor attached to the drive belt is leaking oil (or what appears to be), and now the air conditioning from vents is warm (when it is on cold setting). Is it just refrigerant or somehing else?
Feb 7, 2007 at 5:04 AM
Is the oily substance around the clutch area(between where the belt is attached and the actual compressor), if that is the case then the front seal has failed and you will have to change the compressor. If it is oily where the hose assemblies attach then you can change the o-ring out. Once you have replaced the o-rings or compressor, take your car to a shop to have the refrigerant evacuated since it is illegal to discharge refrigerant into the atmosphere.
Feb 7, 2007 at 11:59 PM
Suggested Repair
If the oily leak is at the clutch between the belt and compressor, the front seal has failed and the compressor should be replaced. If oil is only where the hoses attach, replace the O-rings. After the repair, have a shop evacuate and recharge the refrigerant; do not discharge it into the atmosphere.
Conversation Summary
The owner of a 1998 Chevrolet Monte Carlo with a 3.8L engine reported an oily leak at the belt-driven A/C compressor and warm air from the vents. The expert said a leak around the clutch indicates a failed front seal requiring compressor replacement, while oil at the hose connections can be fixed by replacing the O-rings. After either repair, the system should be professionally evacuated because releasing refrigerant is illegal.
