1995 Chevrolet Monte Carlo AC Stops
VIC136
I'm having problem with my ac. when i step on the accelerator the air stops flowing. If i let go the accelerator air starts blowing again. Any suggestion what might be wrong ? thank you
Aug 8, 2007 at 1:09 PM
CLY
  • 308 POSTS
You have a vacum tank that stores vacum for the actuators for the doors in the heater box. It usually looks like a ball and has a vacum line going into it. I would sugest you find the tank and make sure that you have vacum to it. The plastic vacum lines going to it get brittle with age.
Cly
Aug 8, 2007 at 10:20 PM
Suggested Repair
Locate the vacuum storage tank for the heater-box door actuators, usually a ball-shaped reservoir with a vacuum line, and confirm it holds vacuum. Inspect the plastic vacuum lines, which often become brittle with age, and repair or replace any cracked or leaking lines.
Conversation Summary
The owner of a 1995 Chevrolet Monte Carlo reports that air conditioning airflow stops when accelerating and resumes when the accelerator is released. The expert explains that a vacuum tank supplies the heater-box door actuators and recommends checking that the tank has vacuum and inspecting the aging plastic vacuum lines for leaks.
