2002 Chevy Monte Carlo Sqwealing noise
CESARTALAVERA
  • 2002 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 85,000 MILES
When I start my car it make a very loud sqwealing noise for servral seconds the noise stops and then starts again, it does this several times till it warms up. Could the problem be the alternator, or a pump, I do have the heat on when I start the car. Please let me know what you think it could be. Thank you.
Monday, February 2nd, 2009 AT 7:52 PM
  • 109,885 POSTS
It sounds like you have a belt problem. Check the belt for wear and make sure it is tight. Chances are the belt is worn out or the tensionier has become too weak to keep enough tension on the belt.
Let me know what you find.
Thursday, February 5th, 2009 AT 4:17 PM
