1987 Chevy Monte Carlo Battery Drain
CAPVEE
I have a 1987 Chevy Monte Carlo, 87K, newer engine, 4.3L FI, 22K, whose battery dies in a few days if I don't drive the car or at least start the engine. The battery is 1.5 years old and the alternator is new. With the engine off, I disconnected the negative terminal from the battery and inserted a test light between the negative post and the negative cable - the light is lit showing a draw. One by one, I have removed every fuse and wire from the fuse box - the light stays lit. I have disconnected every electrical connector in the car and wiggled every switch and wire that I can see - the lit stays lit. How do I find this electrical short that is draining the battery every 4 to 5 days? Thanks!
Jun 11, 2007 at 3:11 PM
MERLIN2021
  • 17,250 POSTS
You need more than a test light here...hook up a voltmeter the same as the test light and look for drops as you pull fuses. A normal system will draw about 1 volt!pull fuses til you get a drop of more than the small 1-2 volt drops. Then you are close!
Jul 5, 2007 at 10:08 AM
Suggested Repair
Replace the test light with a voltmeter connected the same way between the negative battery post and cable. Note the reading, then pull fuses one at a time until the voltage drops more than the small 1-2 volt change of a normal system (about 1 volt). Investigate the circuit that causes the larger drop.
Conversation Summary
The owner of a 1987 Chevrolet Monte Carlo says the battery dies within a few days if the car is not driven, despite a fairly new battery and a new alternator. A test light between the negative post and cable stays lit after fuses are removed and connectors are disconnected. The expert advises using a voltmeter the same way and pulling fuses until a larger-than-normal voltage drop identifies the draining circuit.
