2001 monte carlo ls
CHEVY3D
hello , i have a 2001 monte carlo ls v6 3400. the heater and air conditioning only is working on the high setting . it wont work on low or the other 2 lower settings. what could it be and where can i look to fix it . thank you ,i already left a donation.
Apr 11, 2007 at 11:29 AM
2CARPRO JACK
  • 11,533 POSTS
Sorry for the slow response. Sounds like the blower motor resistor or fan speed controller, which ever they call it on that year Monte. Should be located next to the blower motor under the dash, mounted on the a/c-heater plenum
Apr 12, 2007 at 12:42 AM
CHEVY3D
is the plenum thing located in the center of the car below the heater control knobs? thank you
Apr 12, 2007 at 3:50 AM
CHEVY3D
[quote:c4f01ab86a="2CarPro Jack"]Sorry for the slow response. Sounds like the blower motor resistor or fan speed controller, which ever they call it on that year Monte. Should be located next to the blower motor under the dash, mounted on the a/c-heater plenum[/quote:c4f01ab86a]
is there a more specific location to start looking , so i dont disassemble the wrong area? thank you again
Apr 21, 2007 at 4:03 AM
