2001 Chevy Monte Carlo 2001 monte carlo ss
2001 CHEVROLET MONTE CARLO
106,000 MILES • 6 CYL • FWD • AUTOMATIC
DUNBAR8537
My car has a vibration in the front end at aprox 60-70 mikle an hour it is a rolling vibration as in goes back and forth in hoe bad it is It can be felt more on the floors on the passenger side and is minimal in the stearing wheel I have replaced front tires and the front end has been checked and is all tight with no wear noted. It is driving me nuts and my mechanic also. Bill D
May 2, 2009 at 6:34 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:614bceae39="dunbar8537"]Shakes or Wobbles problem
2001 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic 106000 miles
My car has a vibration in the front end at aprox 60-70 mikle an hour it is a rolling vibration as in goes back and forth in hoe bad it is It can be felt more on the floors on the passenger side and is minimal in the stearing wheel I have replaced front tires and the front end has been checked and is all tight with no wear noted. It is driving me nuts and my mechanic also. Bill D[/quote:614bceae39]
Have him check the wheel bearings I had same problem with chevy venture and ended up being the wheel bearings. Had couple of fellow mechanics check it for me and they were stumped. Took it to dealer and they said it was the Wheel Bearings. Change both and no more vibration.
May 2, 2009 at 6:41 AM
MICHELLE68
I had same prob. It was my motor mounts!
Feb 17, 2013 at 11:41 AM
