High front end
2004 CHEVROLET MONTE CARLO
150,000 MILES • 3.4L • V6 • FWD • AUTOMATIC
FITZ BAMBINO
Car was put on a jack to do wheel bearings now the cars front end lifts on any forward acceleration it goes high up only way to get it to Norman is turning the steering wheel left and right or reversing
Aug 31, 2016 at 4:50 AM
SATURNTECH9
  • 30,869 POSTS
Is there any noises? That is a strange thing to happen. Is this a self repair or a shop?
Aug 31, 2016 at 5:34 AM
FITZ BAMBINO
Self repair. noise until its fully down I can see the the strut coming down when the wheel is being turned. when I try to drive it goes fully up to the point controlling the wheel is not an option.
Aug 31, 2016 at 5:44 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like something was left loose your going to have to go back in and see what went wrong.
Aug 31, 2016 at 5:46 AM
FITZ BAMBINO
I have not replaced anything yet, I am trying to figure what is making it, so I can replace it.
Aug 31, 2016 at 5:50 AM
SATURNTECH9
  • 30,869 POSTS
You said you put the car on jack to do the wheel bearing and this happened from doing that? If so what exactly did you do besides Jack the car up? I am flying blind here, I do not know anything that was done without you telling me.
Aug 31, 2016 at 5:59 AM
FITZ BAMBINO
Yes, after replacing wheel bearings the car was 100% drive able drove it to and from work multiple times last time it was jacked up was to change the tire witch was yesterday and now this problem. would it blow the strut leaving it up to long?
Aug 31, 2016 at 6:09 AM
SATURNTECH9
  • 30,869 POSTS
No, unless you had air bags it would not maybe you broke something with the jack when you jacked the car up. You are going to have to jack the car back up and move the wheel around and see where it is loose and what you can see. That is what I would do if I was there with the car.
Aug 31, 2016 at 11:55 AM
