1998 Monte Carlo won't start
MBOYD52601
  • 1998 CHEVROLET MONTE CARLO
I have a 1998 Monte Carlo z34. I had run low on gas and put in two gallons. I tried starting it and the engine would keep turning over but nothing beyond that. I was told to bleed the fuel line but I can't seem to find the valve. Where is it located?
Wednesday, November 14th, 2007 AT 4:50 PM
Turn key to On position-do you hear the fuel pump come On for 2secs. if not you have a power problem-if it comes On and still no fuel delivery check the fuel pressure to rule out the pump and fuel filter.
Need a repair manual for your year/make/model see link below
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, November 14th, 2007 AT 5:30 PM
