1998 Chevy Monte Carlo CAR WONT START
ANTHONY_RCCH
  • 1998 CHEVROLET MONTE CARLO
Engine Mechanical problem
1998 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
HELLO
MY STARTER BURNED OUT BUT MY CAR WAS RUNNING FINE. LAST TIME I TRIED TO START THE CAR IT DIDN'T DO ANYTHING> I REPLACED THE STARTER AND NOW IT START'S TURNING OVER BUT AS SOON AS IT FIRER'S IT IT STALLS.
I HAVE A FILLING SOMEONE ONE PUT SOMETHING IN MY GAS TANK. WHAT SHOULD I DO?
Monday, September 15th, 2008 AT 11:21 AM
RENAUDTN
  • 636 POSTS
Check your fuel pressure, all your ignition system, and vacuum leak.
Also, check your IAC valve.
Do you have any DTCs?
If you suspect bad gas, drain your tank and refill it with good, clean gas.
Monday, September 15th, 2008 AT 11:58 AM
