1998 Chevy Monte Carlo tail lights
1998 CHEVROLET MONTE CARLO
FOOMANSHOE
Electrical problem
for a while i had problems with brake lights.. i discovered that they still worked but i need to pull back my turn signal switch slightly to get them to come on... now my tail lights are completely out but brake lights still work and act the same.. also my instrument panel lights just went out.. do i need to just replace my dimmer switch to fix this problem or is there more to it?? thank you
May 15, 2009 at 2:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Think brake/taillight problem is with turn signal switch.
The dash lights probably dimmer cause power goes from switch through dimmer. So if power gets to dimmer but not to lights replace dimmer. Check gray wire out of dimmer if not hot faulty dimmmer.
Hope this helps
Thanks for donate
May 15, 2009 at 7:20 AM
