1998 Chevy Monte Carlo
MRSCROSS2002
  • 1998 CHEVROLET MONTE CARLO
1998 Chevy Monte Carlo 6 cyl
i'm having problems figuring out why my brake lights won't come on. The middle brake light works but the other tow don't. The bulbs are good, the fuse is good, and the brake sensor is good also. I was hoping you could give me an answer.
thank you
mrscross
Saturday, May 9th, 2009 AT 9:41 PM
  • 109,885 POSTS
Have you checked to see if there is power to the socket? Also, I believe there is a plug under the vehicle to the rear lights that gets corroded at times. Make sure it is ok. Finally, do the rear turn signals work?
Wednesday, May 13th, 2009 AT 2:17 PM
