Brake lights are not working
260,000 MILES • V6 • FWD • AUTOMATIC
MATTHEW MALONE
Brake lights do not work. The turn signals work, blinkers work, but no brake lights what to do to fix it?
Dec 15, 2016 at 2:46 PM
  • 31,937 POSTS
Two thing to check first, check that the fuse has not blown and check the brake light switch. you should have battery voltage at the switch with ignition on and power through the switch when pressed. the switch is located under the dash at the top of the brake pedal.
Dec 15, 2016 at 4:18 PM
