1991 Chevy Monte Carlo No Rear Lights Except Third Brake Li
HAWKEYEJOE
MEMBER
1991 CHEVROLET MONTE CARLO
Electrical problem
1991 Chevy Monte Carlo 130, 00 miles
I've checked/replaced bulbs and fuses. I've got no rear turn signals, brake lights or tail lights.
Help!
Friday, December 5th, 2008 AT 11:32 AM
ZACKSBLONDEE
MEMBER
Try this. When you go to put on the brakes pull forward just a tiny bit on your turn signal handle. I dont know if thats what its called but its on the left side. I have the same problem and I dont know what it is. But if I pull it forward then my lights work!
SPONSORED LINKS
Tuesday, December 9th, 2008 AT 12:22 AM
MIKE H R
MECHANIC
The brake lights and tail lights are on seperate circuits.
You say that you don't have rear signal lights but have front ones. Remove the rear bulb and check using a tester if you are getting power. Then check the ground for the lights. Sometimes a bad ground will cause the lights to stop working.
