1997 Chevy Monte Carlo Cooling system
STEVE HICKE
  • 1997 CHEVROLET MONTE CARLO
  • 6 CYL
  • 135,000 MILES
Tyring to figure out why my radiator is holding too much pressure and allowing my car to over heat. New thermostat and waterpump already on. Pressure build up then goes back in the resivor and over flows once it is realeased.
Tuesday, February 9th, 2010 AT 7:20 PM
  • 109,885 POSTS
The system is to hold pressure. If it is still overheating and you replaced the t-stat and waterpump, check to make sure the radiator isn't plugged. Also, make sure none of the hoses are collapsing when it gets hot.
Let me know what you find.
Monday, February 15th, 2010 AT 12:24 PM
