' 97 Monte Carlo 3.1 Overheating
BSMONTE
  • 1997 CHEVROLET MONTE CARLO
My car is overheating it goes from cold to HOT in 5 minutes All of my antifreeze is going into my overflow reserve and my radiator cap is cold as ice I have changed the thermostat, radiator cap upper and lower radiator hoses drained and refilled with Dexcool and overheating Still. Car has 113,000 miles on it being a ' 97 Monte Carlo (3.1) I didn't flush my system for I am unsure of how to Properly. I am not leaking any fluids and my oil register is clean not cloudy Any suggestions would be Greatly appreciated as I am at a stand still right now Thanks Betty V.
Wednesday, November 14th, 2007 AT 10:04 AM
Do you have white smoke coming out of the tail pipe? If so you have a combustion leakage-meaning the coolant is being burn in the combustion chamber in order for this to happen-it is caused by a blown headgasket, crack head/engine block.
You might want to have the tests below performed.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Need repair manual for your year/make/model see link below
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, November 14th, 2007 AT 5:39 PM
BSMONTE
Thank You I took it to a garage and they put in a new radiator, it seems to be doing fine however I noticed that I still have antifreeze going into my overflow is this normal? I just picked it up today.
And I am not overheating any longer, but I now have a low coolant light coming on Is this normal?
Thank You Once Again Betty V.
Saturday, November 17th, 2007 AT 3:15 PM
