Hello, use a noid lite on the injector plug, crank engine, see if there is a pulse? B+ to the injector goes hot when you turn on the key, the computer switches the ground circuit. Can you check for codes? Possible theft system issue-- cam sensor?
SPONSORED LINKS
Sunday, August 16th, 2009 AT 11:43 AM
