1995 Chevy Monte Carlo Right Blinker
SONOMA52
  • 1995 CHEVROLET MONTE CARLO
  • 4 CYL
  • FWD
  • 128,000 MILES
My right turn signal recently quit. I have no dash lights. I was told that the bulb needed replacing. Can you tell me how to replace thae bulb for the turn signal and if indeed that is my problem.
Saturday, January 12th, 2008 AT 12:38 PM
MASTERTECHTIM
  • 4,750 POSTS
SOUNDS LIKE YOU HAVE 2 PROBLEMS. THE DASH LIGHTS ARE TOTALLY SEPERATE FROM YOUR TURN SIGNALS. SOMETIMES IT CAN BE A LITTLE TRICKY REPLACING THE BULB, YOU SHOULD EITHER LOOK IN A SERVICE MANUAL FOR YOUR EXACT VEHICLE BECAUSE EVERY CAR IS DIFFERENT OR BRING IT TO YOUR LOCAL NEIGHBORHOOD GARAGE. IT SHOULD ONLY COST YOU A FEW DOLLARS. ANYWHERE FROM $5 TO $10 DEPENDING ON THE SHOP. HOPE THIS HELPS
Saturday, January 12th, 2008 AT 12:50 PM
