2004 Chevrolet Malibu Suspension Rattles
BONKO98
i have a 2004 malibu lt and am thinking of replacing the factory struts. will this improve the ride(which is pretty good). there are a few rattles seemingly in the suspension. would you consider replacing other components also? i really do like the car and bought it new.
Mar 20, 2007 at 12:42 PM
SERVICE WRITER
  • 9,123 POSTS
IF the ride is good, find the noises. Fair chance of sway bar links or sway bar bushings at the frame. Get underneath and grab the sway bars and feel for movement. On the bushings, grab the sway bar and feel for any perceptible movement.
IF less than 100,000 miles, I doubt you'll feel $5-600 worth of ride improvement.
Mar 20, 2007 at 1:09 PM
Suggested Repair
If the ride is already good, do not replace the struts just for improvement. Inspect the sway bar links and frame sway bar bushings for play that could cause rattles; strut replacement is unlikely to be worth the cost under 100,000 miles.
Conversation Summary
The owner of a 2004 Chevrolet Malibu LT likes the ride but hears suspension rattles and is considering replacing the factory struts. The expert advises finding the noise first, noting sway bar links or frame bushings as likely causes, and says strut replacement is unlikely to improve the ride enough to justify the cost if mileage is under 100,000.
