2001 Chevrolet Malibu Front Knock
CLIFFP234
i have a 2001 malibu with 65000miles automatic transmission. recently replaced front disc pads and then a few days later starting getting a roaring sound in left front end especially turning left. rotated tires though that tires were worn wrong. didnt help now with the road roar and now i have a hard knocking sound in frontend that hits hard as tires rotate. the faster i go the louder it becomes. please help.
Oct 7, 2007 at 10:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:35091fcd76="cliffp234"]i have a 2001 malibu with 65000miles automatic transmission. recently replaced front disc pads and then a few days later starting getting a roaring sound in left front end especially turning left. rotated tires though that tires were worn wrong. didnt help now with the road roar and now i have a hard knocking sound in frontend that hits hard as tires rotate. the faster i go the louder it becomes. please help.[/quote:35091fcd76]
Make sure u don’t have a loose rim
Some times loose tie rod end will make that noise
And check the work u did on the brakes Calipers tight and dust cover behind the rotor
Good luck
Let us know
Oct 7, 2007 at 10:46 PM
Suggested Repair
Check for a loose wheel or rim, inspect the tie rod ends, and verify the recent brake work: confirm the calipers are tight and the dust cover behind the rotor is not contacting.
Conversation Summary
The owner of a 2001 Chevrolet Malibu with 65,000 miles reported a left-front roaring noise after replacing the front disc pads, especially when turning left. Rotating the tires did not help, and a hard front-end knocking then developed that grew louder with speed. The expert advised checking for a loose rim or loose tie rod end and inspecting the brake work, including caliper tightness and the dust cover behind the rotor.
