1997 Chevy Malibu Front Clicking
JDAVE420
Hey i have a 1997 Chevy Malibu LS with 120,000 miles and i just replaced both lower control arms and now i am hearing a constant (not just when I'm turning) clicking noise from the front end of my car. I am thinking that it might be the CV Joint but i hope not.
Sep 9, 2007 at 6:37 AM
MIKE H R
  • 3,094 POSTS
was this problem there before you changed control arms? If not, Check to make sure everything is on properly. it is possible it could be the cv joint or a bearing. but check everything else first
Sep 9, 2007 at 9:07 AM
JDAVE420
ok i checked already and made sure that every thing was on the way it was before i started. I don't remember if the problem was there before but if it was it wasn't as bad as it is now.
Sep 9, 2007 at 9:21 AM
SERVICE WRITER
  • 9,123 POSTS
One of the CV joints may have been damaged during the repair. The axles are not meant to be pounded on when removing the from the spindle....if that happened.
Don't overlook a wheel cover or wheel cover nut.
Sep 9, 2007 at 2:06 PM
Suggested Repair
Recheck that the lower control arms and related hardware are installed correctly. Inspect the CV joints, especially if an axle was struck while being removed from the spindle, and also check the wheel bearings and wheel covers or wheel-cover nuts.
Conversation Summary
A 1997 Chevrolet Malibu developed a constant front-end clicking noise after both lower control arms were replaced. The owner confirmed the parts appeared installed as before and suspected a CV joint. Replies advised verifying the installation first, then considering a CV joint or wheel bearing, including possible CV-joint damage from pounding an axle during removal, and checking the wheel cover or wheel-cover nut.
