2003 Chevy Malibu Engine Vibrations/hesitation at idle
2003 CHEVROLET MALIBU
105,000 MILES • 6 CYL • FWD • AUTOMATIC
JCROWDER21
I just received a tune-up in which I replaced the spark plugs, serpetine belt, fuel filter, upper and lower radiator hoses and pcv valve. The car ran like a top before this work was done. The engine now noticeably vibrates when in drive and not moving. It is fine in park and after I accelerate. The mechanic mentioned that the new belt may be too tight and I might need a tensioner and that should solve the problem. Is he correct...I really don't want to have to pay for a diagnostic test if this will fix the problem.
Jul 2, 2009 at 7:24 AM
SERVICE WRITER
  • 9,123 POSTS
Not a chance in hell.
Items were:
Spark plugs and pcv valve are the only possible items that I can imagine.
Plugs are the one to focus on, sounds like a miss. Wires might have been damaged in the process. Probably not his fault, they can be difficult.
Check the codes.
Jul 2, 2009 at 12:48 PM
