2001 Chevrolet Malibu ECM Location
TAYLORD1974
I need to know where the ECM is on my 2001 Malibu?
Jan 10, 2006 at 5:24 AM
2CARPRO JACK
  • 11,533 POSTS
the PCM is behind the lower left dash near the steering column. Here is how to change the PCM out and the location, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Let us know if you need anything else.
Jan 10, 2006 at 5:29 AM
Suggested Repair
The PCM (ECM) is behind the lower left dash near the steering column. If replacement is needed, use a preprogrammed unit.
Conversation Summary
The owner asked where the ECM is located on a 2001 Malibu. The expert stated that the PCM is behind the lower left dash near the steering column and noted that a preprogrammed replacement unit can be obtained if the module needs to be changed.
