2000 Chevy Malibu Cranks Then Stalls
JHORTON97
i try to start the car and it will crank, but wont give no gas, then when i start to crank it up after a few times then it just stalls, but the interior and exterior lights and gadgets will come on. i had the fuel filter replaced,and the alternator is still good. i even had a mechanic fix the problem before but he dont know what he did, all he said that he moved some stuff around
Sep 25, 2007 at 7:54 AM
SERVICE WRITER
  • 9,123 POSTS
Check the computer for codes, this sounds like an anti-theft issue. If codes for the anti theft exist, try another key before going further.
Sep 25, 2007 at 8:03 AM
JHORTON97
how do i check the computer codes
Sep 25, 2007 at 8:08 AM
SERVICE WRITER
  • 9,123 POSTS
You can buy a scanner at a parts store, autozone may read them for you, a shop can read them, but will charge.
http://www.2carpros.com/dia/index.htm
Sep 25, 2007 at 11:46 AM
Suggested Repair
Scan the computer for diagnostic trouble codes, especially anti-theft codes. If anti-theft codes are present, try another key before further diagnosis. A parts store, AutoZone, or a shop can read the codes.
Conversation Summary
A 2000 Chevrolet Malibu V6 cranks but does not seem to get fuel, then stalls after repeated start attempts, while the lights and accessories still work. The fuel filter was replaced and the alternator was reported good. The expert advised scanning for codes because the symptoms may indicate an anti-theft issue, and trying another key if anti-theft codes are found.
