2000 Chevy Malibu Blower motor
2000 CHEVROLET MALIBU
GDWEXTREME
Air Conditioning problem
2000 Chevy Malibu 6 cyl Two Wheel Drive Automatic
I have an issue with the blower motor not blowing and I have changed the control switch, motor resistor, and I know that I am getting power at the plug for the blower motor. The blower motor will run if I wire it directly to the battery, is the motor bad or is there possibly a bad ground? Oh, I also replaced the ignition switch because of some other issues if that makes a difference.
Thanks,
gdwextreme
Aug 9, 2010 at 6:38 PM
Your probable causes here could be 2 things the HVAC power module and the AC/Heater programmer.
Aug 9, 2010 at 6:51 PM
GDWEXTREME
I want to thank you for your response to my question and I wanted to let you know that I figured out that the problem was the a/c relay was bad. Thanks again.
Gdwextreme
Aug 14, 2010 at 4:38 PM
TY Sir for coming back and giving us the fix so others can benefit from it-thanks again
Aug 14, 2010 at 7:56 PM
