I RECENTLY BLEW A HEAD GASKET AFTER REPLACING COOLANT TANK AND REPAIRING THE RADIATOR.
WHAT CAUSES A BLOWN HEAD GASKET?
Saturday, December 12th, 2009 AT 4:09 AM
BLUELIGHTNIN6
MECHANIC
Most common cause of a cracked head gasket is overheating / lack of coolant
SPONSORED LINKS
Sunday, December 13th, 2009 AT 6:57 PM
LETTYDELREY
MEMBER
Hmm ok thank you. Here's my situation, hopefully you will be honest. I replaced coolant tank one day took it for a test drive and all the coolant leaked, I t wasn't overheated.I had it towed to a shop and was told it was radiator. Had a radiator tank repaired and took it for a test drive and the check engine and low coolant lights came on. Next day started it up and let it idle 30 min. It didnt overheat or leak but I had it towed back to shop to be sure. 2 days later I was told it was the head gasket and needed new engine. Was there anyway for the shop to know the head gasket was blown before I repaired radiator? I feel as if the shop was just getting more money out of me little by little.
