Hello, how do you know, the engine is getting gas? You can't tell by the initial prime.
If your missing injector pulse with the engine cranking, I'd look for an rpm signal.
Also, At the connector for the ignition module, you can check B+ and ground. Pink wire is B+, goes hot when you turn on the key, black is ground.
SPONSORED LINKS
Wednesday, April 8th, 2009 AT 9:00 AM
