engine
110,000 MILES • 6.0L • 6 CYL • FWD • AUTOMATIC
REDHAYNES46
My engine light just came on but car is running fine. Why would it come on?
Mar 20, 2016 at 11:49 AM
LOU P
  • 118 POSTS
Hello, My name is Lou, there are thousands off reasons the light is on but there are 2 important indicators.
1. if the check engine light is flashing then the engine is misfiring and needs to be shut off or damage will occure
2. its a emissions failure or a engine issue that will cause excess emissions.
the car will not always run bad for the check engine light to come on. that is a common misconception. so what i can recommend is at your earliest convenience head over to your local parts store and they can read the codes at no charge and hopefully they can advise from there what to do. BUT i always recommend having the codes diagnoses at a shop as most parts stores only can guess at the actual issue. hope this helps Lou .
Mar 20, 2016 at 1:00 PM
CJ MEDEVAC
  • 11,000 POSTS
SOME PROBLEMS ARE NOT "TANGIBLE", THEY MIGHT NOT "STAND OUT". THEY MIGHT BE SERIOUS, SOON WILL BE SERIOUS, OR MAYBE NOT SO SERIOUS.
THERE IS ONLY ONE CHECK ENGINE LIGHT AND THE POSSIBILITY OF HUNDREDS OF FAULT CODES TO TURN IT ON!
YOU CAN HAVE THE CODES SCANNED AT A POPULAR AUTO PARTS STORE, USUALLY THIS IS A FREE SERVICE (SUCH AS AT AUTOZONE)
YOUR COMPUTER HAS IDENTIFIED THERE IS A FAULT OF SOME KIND, AS IT WAS DESIGNED TO DO, IT MIGHT RANGE FROM A BAD O2 SENSOR ROBBING YOU OF FUEL EFFICIENCY OR MAYBE AS SIMPLE AS A GAS CAP NOT SEALING CORRECTLY.
IF YOU GET IT TESTED/ CHECKED (LIKE ANY CONCERNED OWNER OF A MULTI-THOUSAND DOLLAR MACHINE SHOULD) WRITE DOWN THE EXACT CODE NUMBERS (NOT JUST WHAT THEY SAY THEY MIGHT MEAN, THEY CAN BE INTERPRETED IN DIFFERENT WAYS)
IF YOU CAN'T STRAIGHTEN THINGS OUT ON YOUR END, RETURN WITH THE NUMBERS HERE, MAYBE OUR GUYS CAN AID IN GETTING YOUR VEHICLE UP TO PAR!
THE MEDIC
Mar 20, 2016 at 1:12 PM
