Engine Performance problem
1982 Chevy Malibu V8 Two Wheel Drive Automatic
i have a chevy with a holly carberator and at an idle I have gas running through my secondaries. How do I fix this
Saturday, June 12th, 2010 AT 2:22 PM
DOCFIXIT
MECHANIC
First check float level of rear bowl. Remove screw on side of bowl fuel should not run out. If it does see nut with screw on top of bowl loosen turn screw down to lower fuel level. Also check to see if secondary throttle plates are shut.
