1994 Chevrolet Lumina Window Stuck Down Fix
SMILLS40
The driver power window is down on my '94 Lumina 4 door sedan and is no longer working. How do I get it back up manually. I want it up until I find a new control switch for it. The passenger window does not work either but is up.
The back windows work.
Thanks for any help!
Sep 7, 2007 at 8:56 AM
MERLIN2021
  • 17,250 POSTS
you will need to remove the door panel then the window motor, then pull up on the glass, then either brace it or put the motor back on so the glass stays up!
Sep 7, 2007 at 10:02 AM
Suggested Repair
Remove the door panel and window motor, pull the glass up by hand, then brace it or reinstall the motor so the window stays up.
Conversation Summary
The owner of a 1994 Chevrolet Lumina has a driver power window stuck down and wants to raise it manually until a new control switch is found. The passenger window also does not work but is already up, while the rear windows work. The expert advises removing the door panel and window motor, pulling the glass up, then bracing it or reinstalling the motor to hold it in place.
