1994 Chevy Lumina Hesitates and Dies
JEFFROHOTROD
  • 31 POSTS
I have a 94 chevy lumina 3.1 208,000. When I accelerate it hesitates and stumbles and sometimes it dies. While trying to give it gas it occasionaly backfires. I have changed fuel pump, fuel filter, plugs, wires, egr valve, tps, idle air control valve, knock sensor, pcv valve and all vacuum hoses, crankshaft position sensor. It doesn't sound too bad when idling it just won't go anywhere. Can somebody PLEASE help me? I am thinking it might be the computer?
Aug 10, 2007 at 2:41 AM
  • 75,988 POSTS
[quote:5456125238="jeffrohotrod"]I have a 94 chevy lumina 3.1 208,000. When I accelerate it hesitates and stumbles and sometimes it dies. While trying to give it gas it occasionaly backfires. I have changed fuel pump, fuel filter, plugs, wires, egr valve, tps, idle air control valve, knock sensor, pcv valve and all vacuum hoses, crankshaft position sensor. It doesn't sound too bad when idling it just won't go anywhere. Can somebody PLEASE help me? I am thinking it might be the computer?[/quote:5456125238]
Does it shifts okay in every gear.
Did you check the ignition timing? Did you change the O2 sensor/s also the fuel pressure.
I recommed you get it scanned with or w/o code/s might tell you something, the PCM is your last resort.
Aug 13, 2007 at 12:22 AM
JEFFROHOTROD
  • 31 POSTS
It shifts just fine. The timing is good and I have changed the o2 sensor. It keeps coming up with a code 42 which I finally found out is the prom chip. I am going to change it and hopefully it will fix it
Aug 13, 2007 at 1:07 PM
JEFFROHOTROD
  • 31 POSTS
I have now changed the computer, air charge sensor, at first it would do the same start but didn't want to go anywhere when i gave it gas but now when i start it, it revs up then right back down and dies. What else could it be i'v changed everything i can think of.
Sep 4, 2007 at 2:42 AM
  • 75,988 POSTS
[quote:32c8379c49="jeffrohotrod"]I have now changed the computer, air charge sensor, at first it would do the same start but didn't want to go anywhere when i gave it gas but now when i start it, it revs up then right back down and dies. What else could it be i'v changed everything i can think of.[/quote:32c8379c49]
Get a helper-have him/her crank it up-when it dies immediately check for spark-got spark check the fuel pressure. You got to do this fast to catch it while on the act.
BTW did you check the MAP sensor
Sep 4, 2007 at 7:38 AM
JEFFROHOTROD
  • 31 POSTS
It is getting spark and fuel pressure. When I changed the computer then started it the check engine light came on for map sensor so i am going to change it this week. But when i test drove it it was acting like it did not want to shift out of first it would just keep reving up and would not shift and backfire. I tried to shift manually but it still would not go past first gear. Is there a sensor for the torque convertor or what could that be?
Sep 14, 2007 at 3:40 AM
  • 75,988 POSTS
[quote:d5789e0072="jeffrohotrod"]It is getting spark and fuel pressure. When I changed the computer then started it the check engine light came on for map sensor so i am going to change it this week. But when i test drove it it was acting like it did not want to shift out of first it would just keep reving up and would not shift and backfire. I tried to shift manually but it still would not go past first gear. Is there a sensor for the torque convertor or what could that be?[/quote:d5789e0072]
Try disconnecting the TCC solenoid and retest.
Sep 14, 2007 at 7:46 AM
JEFFROHOTROD
  • 31 POSTS
Where is the tcc solenoid located at?
Sep 25, 2007 at 7:58 AM
  • 75,988 POSTS
[quote:a3071720c9="jeffrohotrod"]Where is the tcc solenoid located at?[/quote:a3071720c9]
Its inside the tranny attached to the valve body.
Sep 25, 2007 at 9:02 AM
Suggested Repair
Scan for codes and treat the PCM as a last resort. With spark and fuel pressure present and a MAP-sensor code after the computer swap, test or replace the MAP sensor. For the no-shift/revving condition, disconnect the TCC solenoid and retest; it is inside the transmission on the valve body.
Conversation Summary
A 1994 Chevrolet Lumina 3.1 with high mileage hesitates, stumbles, backfires, and sometimes dies under acceleration despite many parts already being replaced. Timing, shifting, and the oxygen sensor were reported good, and a code 42 led the owner to replace the PROM/computer and air-charge sensor. After that, the engine revved and died, spark and fuel pressure were present, and a MAP-sensor code appeared. On a test drive it also would not shift out of first and backfired. The expert advised checking spark and fuel pressure immediately after it dies, checking the MAP sensor, and disconnecting the TCC solenoid to retest the shift problem.
