1994 Chevy Lumina Hesitates and Dies
Does it shifts okay in every gear.
Did you check the ignition timing? Did you change the O2 sensor/s also the fuel pressure.
I recommed you get it scanned with or w/o code/s might tell you something, the PCM is your last resort.
Get a helper-have him/her crank it up-when it dies immediately check for spark-got spark check the fuel pressure. You got to do this fast to catch it while on the act.
BTW did you check the MAP sensor
Try disconnecting the TCC solenoid and retest.
Its inside the tranny attached to the valve body.
Suggested Repair
Scan for codes and treat the PCM as a last resort. With spark and fuel pressure present and a MAP-sensor code after the computer swap, test or replace the MAP sensor. For the no-shift/revving condition, disconnect the TCC solenoid and retest; it is inside the transmission on the valve body.
Conversation Summary
A 1994 Chevrolet Lumina 3.1 with high mileage hesitates, stumbles, backfires, and sometimes dies under acceleration despite many parts already being replaced. Timing, shifting, and the oxygen sensor were reported good, and a code 42 led the owner to replace the PROM/computer and air-charge sensor. After that, the engine revved and died, spark and fuel pressure were present, and a MAP-sensor code appeared. On a test drive it also would not shift out of first and backfired. The expert advised checking spark and fuel pressure immediately after it dies, checking the MAP sensor, and disconnecting the TCC solenoid to retest the shift problem.
