Thank you for providing the code.
What you need to do is to check that the wiring isn't routed too close to any secondary ignition components (coil, spark plug wires, etc.)
Visually inspect the wiring at the sensor for any burn marks, discoloration indicative of melting or chafing
Check for poor wiring connection at PCM.
Visually inspect the reluctor wheel through the cam sensor port for any missing teeth or any damage'
Thank you for using 2carpros. Com
SPONSORED LINKS
Monday, July 31st, 2017 AT 11:40 AM
(Merged)
