1997 Chevrolet Lumina Fuel Pump Failure
DCLEAVE
I have a 97 lumina car with 147,000km. I bought it with 53,000km. I am now having to replace my second fuel pump in the car ( $1000 repair). I looked at my previous invoice and the fule filter was changed. I am now wondering if I should have the fule tank steam cleaned? The mechanic I have working on it says no.
Waht could be causing these fule pumps to malfunction so quickly?
Thanks for your help!
Dcleave
Nov 28, 2007 at 8:19 AM
  • 75,988 POSTS
Bad connections-due to voltage drop in the circuit.
Nov 28, 2007 at 10:00 AM
Suggested Repair
Check the fuel pump circuit for bad connections and voltage drop before replacing another pump or cleaning the tank.
Conversation Summary
The owner of a 1997 Chevrolet Lumina with 147,000 km is replacing a second fuel pump and asks whether the tank should be steam cleaned after the fuel filter was already replaced. The mechanic advised against cleaning. The expert attributed the repeated pump failures to bad connections causing voltage drop in the circuit.
