1991 Chevy Lumina Fuel Gauge Wrong
VJV3017
I drive a 1991 Chevy Lumina (about 36,000 miles) and I really don't understand the fuel gauge. When I turn my car off the gauge shows me how much gas I have. So if I have half of a tank of gas when the car is on, when I turn the car off, the gauge still reads half of a tank. Then when I drive, the needle moves around quite a bit, because it's a floating gas gauge, so it can be hard to tell how much gas I have when I'm driving, so I tend to rely more on what the gas gauge says when the car is parked and turned off, and it has been really accurate until now. It seems that when I get to quarter of a tank of gas or below, every time I turn the car on, the needle goes down to empty, and then when I turn it off after driving, the needle will display an amount that seems more accurate. For example, the gauge will say that I have a quarter of a tank of gas, I'll turn the car on, the needle goes to empty, I'll drive somewhere, and then when I turn the car off again, the needle will show that I have slightly less than quarter of a tank, which is the amount I would expect to have. Well last night, I got stranded because the gauge said I had a little less than a quarter of a tank of gas when it was off when apparently it didn't. Is this a normal occurance with older cars? I really don't understand why the gauge would be more accurate when the car is off and when I have more than a quarter of a tank of gas in it. Could there be something wrong with my car? I've been driving it for over a year now and I didn't have any problems with gauge until maybe two weeks or so ago.
Sep 15, 2007 at 12:50 AM
  • 75,988 POSTS
[quote:dcde9111dc="VJV3017"]I drive a 1991 Chevy Lumina (about 36,000 miles) and I really don't understand the fuel gauge. When I turn my car off the gauge shows me how much gas I have. So if I have half of a tank of gas when the car is on, when I turn the car off, the gauge still reads half of a tank. Then when I drive, the needle moves around quite a bit, because it's a floating gas gauge, so it can be hard to tell how much gas I have when I'm driving, so I tend to rely more on what the gas gauge says when the car is parked and turned off, and it has been really accurate until now. It seems that when I get to quarter of a tank of gas or below, every time I turn the car on, the needle goes down to empty, and then when I turn it off after driving, the needle will display an amount that seems more accurate. For example, the gauge will say that I have a quarter of a tank of gas, I'll turn the car on, the needle goes to empty, I'll drive somewhere, and then when I turn the car off again, the needle will show that I have slightly less than quarter of a tank, which is the amount I would expect to have. Well last night, I got stranded because the gauge said I had a little less than a quarter of a tank of gas when it was off when apparently it didn't. Is this a normal occurance with older cars? I really don't understand why the gauge would be more accurate when the car is off and when I have more than a quarter of a tank of gas in it. Could there be something wrong with my car? I've been driving it for over a year now and I didn't have any problems with gauge until maybe two weeks or so ago.[/quote:dcde9111dc]
You have a problem with the fuel sending unit in the fuel tank
Sep 17, 2007 at 7:46 AM
Suggested Repair
Inspect and replace the fuel sending unit in the fuel tank, which is the likely cause of the inaccurate gauge readings.
Conversation Summary
The owner of a 1991 Chevy Lumina reports that the fuel gauge moves while driving and, below about a quarter tank, drops to empty with the ignition on, then shows a seemingly higher reading when the car is off. Relying on the off reading led to running out of fuel. The expert says the fuel sending unit in the tank is faulty.
