Missing w/ speedometer jumping
DWARREN
  • CHEVROLET LUMINA
97 Chev Lumina, 106K miles, 6 cyl auto. At highway speeds my car occasionally misses, sometimes so bad it shudders and the speedometer jumps up and down. One mechanic guessed oil pan gasket and manifold gasket ($1600), another suggests it may be a bad coil pack. Have you heard of these symptoms? Thanks for your expertise.
Monday, November 19th, 2007 AT 11:14 AM
When was the last major tune-up?
Does it have a check engine light On or has flashed if so you need to have the OBD2 read and comeback with the code/s.
For a start check the fuel pressure with a gauge.
Monday, November 19th, 2007 AT 12:11 PM
